hey guys, heres one that i have never done, and hopefully sombody has the solution.
i have a couple of diffrent episodes of beavis and butthead on my drive as vob's, (there is a diffrent vob folder, for each episode). now i want to combine them all into one, so that i can burn them on to dvd. how can i do this?
anything will help.
thanxs.
Hello,
Many programs like tmpgenc dvd author will accept vob files. Just load the vob in and make your menus as you see fit. If its too large you can always use dvdshrink to get it back down if you go over
yeah, i know about burning vobs, i have been doing video for a while, but the problem is that, all my episode are all in seperate folders. here is the problem exactly: all my folders have a vts_01_1.vob file along with the ifo's and bup's. now the reason i cant youse dvd shrink or tmpg is because, all the files are named the same (vts_01_1.vob etc). i have tried renaming the files in order starting with my first folder as vts_01_1.vob, then go to my next folder and rename that vob to vts_02_2.vob and then the next folder and rename to 03 etc etc. you get the point right? anyways when i try to open in any dvd author app, i get an error of some type. the only way i can think of doing this, is to convert to svcd, and then burning with vegas, or adobe, but the problem is, that i dont want to loose quality in the conversion. i know this is possible without conversion, but how?
thaxs again. -
hey guys scratch that, i just tried tmpg again, and instead of just trying to burn, i created a project this time, then just added the files, it then split them into seperate files. it's encoding right now as i speak, 16 minuits till burning, i will let you know if it comes out as planned.
thanxs again.
How to record a DVD using a software?
By coxanhvn in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2009, 20:57 -
Routing audio from PC to diffrent speakers?
By blackflag10 in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2009, 18:49 -
Save between diffrent encoder
By Cazz in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2008, 17:50 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 12:37 -
VOB files - Video _ TS folder wont record dts codec on toast 7
By BattyRoy in forum MacReplies: 8Last Post: 10th Apr 2008, 00:30
