This error happens with only one particular .avi of many
that i attempt to add to assets .Yet they all come from
the same source .
There was no log of these events available in log folder
so i cant send a log
Can someone please advise ?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at av_find_stream_info(AVFormatContext* )
at SVCD2DVDLib.Info..ctor(String Filename)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xca3a7a432977a ec0(Array x19218ffab70283ef)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1867.33802
Win32 Version: 2.0.1867.33802
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
System.Windows.Forms
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 4.7.0.0
Win32 Version: 4.7.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
SVCD2DVDLib
Assembly Version: 1.0.1867.22426
Win32 Version:
CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
Microsoft.VisualC
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Is the avi big? Do you fancy uploading it to my ftp server?
No m8 its not big .
i believe it`s under 200 mb
i do believe i may have found the problem tho .
i tried to open the .avi in gspot , an .avi codec reader ,
& it said it wasn`t a valid .avi file .
its suppose to be episode 14 of a tv series , but when i`m able
to play , (only about 3 seconds of it ) in vlc , it is some sweet blonde
woman topless . i dont think thats the tv show , i`m not sure how this
file got into this collection marked as episode 14 .
May that explain the error i got ?
thanks m8 -
Hi m8
Well i don`t feel a need to u/l the file now & waste your time
when it seems a fact its a corrupt file .
i know your busy , but if it`s part of , or can help you learn anything
i would u/l it for you . But since it`s not svcd2dvd related i won`t
stress over it any .
PS
man i love this program you desigened...& i just thought imagine wot
it would do if it had multi layer support.....a ton of movies on 1 dvd....
But i can`t afford the media @ this point..nor if i could , would i spend
over $ 10,, / disc.......so maybe in the future..i`m just talking out loud
Cheers
unhandled exception - length cannot be less than zero
By warresg in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2010, 17:49 -
"An unhandled exception occurred in 3rd party module and will be close
By BLSAMPLES in forum ComputerReplies: 4Last Post: 12th Jul 2009, 23:30 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 05:43 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 15:15 -
an unhandled exception has occured in your application
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Jun 2007, 17:54
