If I have my speakers on while surfing the net there is constant static that comes out my speakers? Any ideas why this is happening. Gets annoying after 5 or 6 webpage changes.
What We Do In Life, Echoes In Eternity....
eh cheap soundcard or onboard sound?
you might also have line in or mic turned up try muting those through control panel>sound and audio devices>advanced
btw broncos still suck
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Nope no luck with those...
What We Do In Life, Echoes In Eternity.... -
are u using onboard audio? mine usually sounds pretty good but i get weird noises too. just one of those things....you could try getting rid of the bronco stuff on your puter and puting some raider stuff on it, helped me
How far up have you turned the speakers? Maybe try turning them down, or shut them off when youre online.
Is you soundcard and modem all in one, or separate boards. For me, using a modem separate from sound card helped. If you have some kind of sound control program, try using the Mic Monitor (Disconnect Modem From Speakers) option (or similar feature)
Are using Dial-Up? That stuff causes much trouble than it is worth. Maybe it's time to upgrade to broadband. -
Maybe try updating your sound drivers. I had funny noises through my speaker once when I moved my cordless mouse updating the drivers fixed it for me.
Even with speakers turned all the way down still get static. Using Boradband, using external modem.
glockjs,
You're just upset that the last time your team made it to the big game, they got their asses handed to them by the lowly Bucs.......atleast my team went back to back against the Pack, and ATL with Anderson in the back field.What We Do In Life, Echoes In Eternity....
PC Speakers, which ones?
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 28th Sep 2011, 15:41 -
5.1 on stereo speakers
By capibat in forum Software PlayingReplies: 4Last Post: 19th May 2011, 20:47 -
DIY speakers?
By Haopengyou in forum Off topicReplies: 3Last Post: 21st Jun 2010, 00:33 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Output to 5.1 speakers
By LabanB in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Dec 2008, 13:39
