Well I've had my Mac for a couple of days, and I just tested out MTR, DVD2one, and Toast. For some reason when printing on a dvd with my r200, the image prints off center. I've tried reinstalling and realligning and still no clue on why this is happening. This never did this when I had it hooked up to my PC. Any suggestions?
What program are you using to print on your discs? I use Magic Mouse Discus and it prints perfectly without any realignment using the Epson R200 template that is in the program.
I'm using the software that came with my epson r200. it was working fine with my PC, then when i switched over to the Mac, it's off centered. Is Magic mouse free?
I have the R800 but the soft is the same...
1) page setup (US letter Vert)
2) R200 Manual feed
3) File "Adjust print position"
4) adjust & "Ok"
the settings will be saved
A note:
If you have more than 1 printer installed (I have 4) you have to make your R200 manual feed "default" or the print settings will "divert" to another setting inside "Epson Print CD" every time (at least that’s what happened to me). Until I made my R800 manual feed "default"
Hope something here helps you out... "glad to see you working on a Mac"
Cd
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 18:29
