I´m having a problem to load a file on VirtualDub, It´s a MKV file With audio end subtitles embed, it crashes, and i would like to extract the files to put in a DVD format.
Anyone can help?
VirtualDub does not support mkv files, however I assume that you meant VirtualDubMod, which unfortunatly has not been updated in ages, unlike the mkv format. As such newer files sometimes cause it to crash.
Try MKVExtract or mencoder/mplayer instead. -
yep, try mkvextractgui.
celtic_druid: you can write just mencoder...it will link to mplayer now.
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
