Hello, Hopefully right forum
Now that I decided to get the Lite-On 1633S drive
My question is: Would there be a benefit to me to start using their bitsetting utility to set the booktype, given that the disks I created in My Sony's never had that done and play evrywhere I've tried them?
Second question is if I understand it properly the procedure is first set the disk to a DVD-ROM booktype and then burn?
But if you set the booktype to DVD-Rom why doesn't that cause the burning application to say no way, I can't burn a DVD-ROM?
Hopefully these are not stupid questions.
Cheers
if you're going to use DVD+R media then set the disk to booktype to DVD-ROM and then burn.
your second question is confusing. if you need more help go to the LITEON FORUM at cdfreaks.com
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&f=44 -
Boy, what a stupid question!!!
I'm kidding.
You are telling it to read it as a DVD-ROM, although it was burnt as a DVD+R/RW.
All DVD players are required to read, and play, the DVD-ROM format, and they just check one bit to determine what the format is. If that bit is set to DVD-ROM, MOST machines will read it. It tells the player what strategy it must use to tead it.
It works. My g'daughter's PSII will not read anything but a + bitset to ROM. My daughter's Samsung, also will not read any of my backups unless burnt as ROM. Makes it tough for me to take a bunch of DVD backups to babysit the g'son, unless I make them ROMs.
Cheers,
George -
Actually, its more than one bit, but the the rest of the explanation is right.
CC,
I thought it was more than just ONE bit, also, but setting ONE BIT just seems so much more explicable than 27 varied bits, or whatever.
Regardless, it does generally work.
Cheers,
George -
Thanks all, That explanation makes it clearer. Logic said to me that if I mark it as a DVD-ROM then the burning s/w will choke. But it appears they are different settings, On for reading and a separate area for write strategy and such.
Cheers
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 13:39 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 10:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:58 -
Enabling Bitsetting on Pioneer DVR 215
By here2rock in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 04:29 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 22:33
