Hi there! (Hope this is the right forum to ask this):
there's a divx file that I'm trying to convert to mpeg2 using tmpgenc and it just keep saying at the begginning and ending of the encoding: "nothing to bserv. Decoder lag" on the preview window. But it encodes anyway. But sometimes it leaves the message encoded in the beg. or end of the movie file.
So.........what's wrong? Any tips?
thanx a lot for any info!
Nothing wrong,its an xvid file and gives me that message also,i change the header to divx with nics 4 cc changer to get rid of it.
Originally Posted by johns0I think,therefore i am a hamster.
ok, got the message! But I didnt find the specific 4 cc changer. Instead I got AVI FourCC Changer (or maybe it's this one u meant?) anyway, I've tried to change on the software: used codec: xvid / codec description: divx
I just wrote the codecs, since the preset alternatives were strange to me, like MPG41 or something...
but nothing worked. still the same message on tmpgenc.
Whats going wrong? thanx! -
If you installed the newest xvid codec the nics 4 cc changer would be in your start menu,what you can do also in tmpgenc is goto settings/advanced/source range and adjust to cut out those messages.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
