Format the disc twice? ... Hmm.....![]()
Results 31 to 34 of 34
Yes. I know it sound crazy. But, this is how I concluded..
When a disk comes pre formatted, it is formatted from the factory
that *stamped* it. The format (IMO) is not 100% spot on with the
method the my iLO dvd recorder (or yours for that matter) produces.
When I first started recorded onto the included disk, I was
experiencing/having all sorts of issues with bringing it to my PC
and reading it. It would drive my ROM drives mad, and lock up my
pc most of the times. But, after I re-formated, consiquentually
removing the *stamped* formate of the factories formatit
would play (read) flawlessly. I found, however, that if I re-formatted
twice (8 seconds worth) from the iLO unit, it would give me what I
consider so far, a guarentee flawless disk. (I hope no one puts
the wammy on me now)
So, I consider that a great TIP. And one to be used in all your
required dvd recorder projects
Good luck,
-vhelp 3157 -
I don't care if it sounds nuts or not ... I'm going to try it.... I have oddities every now and then on the LiteOn with certain "problem" DVD+RW media that can only be read in a certain drive of mine.
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 15:40 -
region code assistance needed with the sony ns-700h dvd player
By stressed_with_sony in forum DVD RippingReplies: 1Last Post: 2nd Jun 2009, 00:53 -
Saw AWESOME HD recorder. No copy protection. HD out. Set top. Real time.
By Evilmind in forum Newbie / General discussionsReplies: 7Last Post: 13th Aug 2008, 18:56 -
choosing the good dvd recorder ?
By cccf25 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th May 2008, 10:43 -
Help, unable to rip DVD created from a set top DVD recorder.
By pwangdel in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2007, 18:47
