  1. i have a tv thats cable ready but has no rca line outs on it could i still record from tv on to my computer using an ati aiw 8500 dv? if so what do i hook were thanks rick
    rick thomas
    Read the documentation that came with the card.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    How are you getting your TV?
    Rabbit ears?
    Roof ant?
    Cable?
    Sat?
    Is there a box with ins and outs ?
  4. i have cable pluged into the vcr rf in then rf out to tv uhf via a radio shack matching transformer adapter(75 downlead to 300-ohm antenna). im using the vcr as tuner but only seeing channels 1-12 . the higher channells are blue no pic. am i hooked up right ? this tv has got line out ,tv out , monitor out, line in and same for audio
    rick thomas
    Nov 2003
    Moreno Valley, Ca
    In your pc software program, there should be an option to select source
    antena will only give broadcat channels
    catv will give extra channels
    if on digital or sattelite you can only get channel that is showing on tv/vcr that is selected via cable box decoder
  6. Cable channels 14-99 are not the same as UHF. Your VCR should have a setting for the upper channels -- a switch between UHF and Cable. Then you don't need the UHF splitter.
  7. ATI cards use a free program from ATI to make your computer into a PVR. Its called Gemstar Guide Plus or something.
  8. thanks guys you have been a really big help . i was able to solve the problem i had not being able to get the upper channels of tv through the vcr . it seems that my vcr was set up in the menue for ant. instead of cable . thanks to all the input from you all i was able to put 2+2 together and solve the problem . my next step is to get it all working with my ati aiw card .thanks for all your help rick
    rick thomas
