I want to burn a DVD Video and when I insert a blank DVD and go to Nero Express, the option for burning a DVD video doesn't appear. The only way I can access the DVD video option is if I click on Nero Buring Rom and click on "DVD Video" and when I do that it says "No compatible recorder detected",but I have a DVD burner and I thought all DVD burners work with Nero. Someone please tell me what am I doing wrong.
Not all burners work with all versions.
That is strange, I can select DVD-Video even on a computer that doesn't have a DVD writter attached.Originally Posted by Phillydogg
You can always author to a Video_TS on the HDD. Try reinstalling your nero.
Or you may have a crippled version. -
Nero Product Information > Supported Recorders heading > search <select a manfuacturer>
http://www.nero.com/us/recorders66.php
You may need to enable Burn Right to allow other than Admin's to burn with the drive. [Edit] I doubt that is the issue but included it anyway.
edTV I don't think he is using Nero Vision Express to author a DVD.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
