Hi, any ideas on how to back up old vhs commerial tapes to dvd. I have a canopus 100 and new liteon 16 dvd dl burner and I'm using either Nero6 Ultra Edition or Ulead MediaStudio Pro 7. Decoding is the problem, but I saw a seller of a canopus 100 on ebay saying that there is a way to set up the converter to read the old vhs tapes. I have tons and some you can't get any longer on tape or DVD, hoping to makes back ups for my kids and thier kids. Any help would be great. ThanksK9bliss
The way I do it with a ACVC-100: Transfer to the computer with WinDV. Filter and edit in VirtualdubMod, encode with TMPGEnc encoder and author with TMPGEnc DVD Author. You need a decent VHS player. A TBC is recommended, but I do fine with just a cheap JVC VHS player.
If you are talking about Macrovision disabling with the ADVC, then the older units do it, not sure about the newer ones. You hold down the input switch for about 15 seconds and that should disable Macrovision.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
Copy inhibit signal prevents me from backing up my old VHS tapes
By ShaneJensen in forum Capturing and VCRReplies: 33Last Post: 28th Jun 2010, 21:39 -
Backing up video tapes with windows media center
By macmaster in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2009, 17:19 -
Backing-up Vhs movie tapes to Dvd
By Gerald Sr. in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2008, 00:23
K9bliss
