Hi!
Problem: When I play a DVD on my PC the movie isn't smooth.
My settings:
* 6x DVD (Creative), no Dxr3 Card (only Software Decoder)
* WinDVD
* Pentium 4 1.4 GH
* 384 MB RAM
Does anyone have an idea? Would a faster DVD drive help?
have a nice day,
Picard007_98
Windows device manager, go to the IDE channel things and go to the properties for these. Make sure use DMA if available is checked. Also if you have your CDROM drives on the same cable as your HD the speed of transfer will be limited to UDMA 33 (most hd are now UDMA 66 or 100). You HD should be on a seperate cable if at all possible.
Which is better for speed and performance?
By SIRCOOKS in forum ComputerReplies: 3Last Post: 20th May 2010, 23:03 -
Concerned about PC performance
By mattman1968 in forum ComputerReplies: 4Last Post: 23rd Oct 2008, 11:31 -
FFMpeg performance
By aeroliteflyer in forum DVD RippingReplies: 12Last Post: 18th Mar 2008, 20:47 -
CRYSIS performance
By retroborg in forum Off topicReplies: 4Last Post: 13th Dec 2007, 07:55 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 11:31
