Ever since I downloaded the latest upgrades for Nero 6 (version 6.6.0.6) I have lip sync problems when burning films. It starts off ok, but as the movie goes on, it gets progressively worse, ending up with the sound being about 2 seconds before the picture.
Any ideas around it?
Can you describe your process? I use Nero 6.6.0.6 and don't have this problem.Originally Posted by Wilco
The only time I get audio sync problems is when recording VHS via passthrough with my digital camcorder. But that's actually normal (unfortunately) and has to be fixed after the fact. -
I have a file (.avi) that I've downloaded. If I watch the .avi file on my computer then there is no problem, but when I try to burn the file using Nero Startsmart I get the lip sync problems. It only happens since I got the latest set of upgrades from nero.com.
AVI is a very general audio/video "container". What's inside?Originally Posted by Wilco
Wilco,
What format are you burning to VCD/SVCD/DVD ?
Don't use nero to encode your AVI to the desired format. Use an external encoder like TMPGEnc etc to encode your file and THEN use nero to burn your disk. If you face sync problem you can use VirtualDub to frameserve to TEMPGEnc or any other encoder you are using.
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 10:23 -
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 17:36 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 11:16 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 05:47 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 16:53
