  1. does anyone got any tips when using winfast pvr for capturing with the winfast pvr software.
    what i really need is some settings configuration.
    here is what i have so far.
    170 minute recording
    video quality 1000
    target data rate 4600
    resolution 352x240
    there is no documentation on how on capture profile settings everytime i try to change it goes to 480x480 instead of another resolution.
    i have one profile as of now. i need more but i dont know where to look.
    this program makes no sense at all..
    i made another profile with these settings.
    video quality 400
    target data rate 6000
    resolution 720x480
    with this setting i am able to captue up to a 130 minute of video.
    i did the math average file size is around 33.4 to 34.0 times that times 120 and its around 4080 and 130x34=130 minutes of recording time.
    this program is a nuisance to use i found out that if you drop the target data rate below 6000 it will only make SVCD's which makes no sense whatsoever..
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Google is your Friend
