Has anyone used these before? I just got one and I for some reason cant get in the configuration utility for it. It says to just connect the cable for the LAN card on the pc to the lan port on the router and enter 192.168.10.1 into a browser address bar and it will take you to the config page. Well everytime I do it, it just comes up page not found?
I read the motorola help file and it just says if you cant connect, just make sure the cables are connected.
Any thoughts? LOL
A bird in the hand is worth a foot in the tush-Kelly Bundy
Hello,
Are you sure it isn't 192.168.0.1???????
Mine defaults to 192.168.0.1
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
I give it a try but the guide it came with listed 192.168.10.1
Thanks for the addy though I am gonna try it now.
A bird in the hand is worth a foot in the tush-Kelly Bundy -
Just tried, no luck. The software the router comes with freezes when trying to run it, I wonder about Motorola sometimes.
Are those linksys ones any better?A bird in the hand is worth a foot in the tush-Kelly Bundy
Top rated wireless routers
By neworldman in forum ComputerReplies: 8Last Post: 6th Sep 2010, 02:44 -
Wireless N routers 150mbps vs 300mpbs
By WinSpecToR in forum ComputerReplies: 5Last Post: 16th Aug 2009, 03:04 -
How do you configure a motorola sb5120 for a wireless router?
By yoda313 in forum ComputerReplies: 3Last Post: 22nd May 2009, 15:59 -
Can I get 2 wireless routers to talk to each other?
By stblob in forum ComputerReplies: 2Last Post: 25th Feb 2008, 12:39 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56
