  1. Banned
    Dec 2004
    SE4
    Hi,
    Ive been trying to network 2 computers they can see each other alright its just when i go to put one file onto the other machine over the network i get you do not have permission or access denied file is write protected and stuffl ike that..
    help please..
    cheers
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I haven't been able to that stuff successfully very much. BUT try creating a folder called "shared" and right click it. I believe there should be an "ALL ACCESS" choice. If not go to the control panel and somewhere there should be an option to enable file sharing.....
    Kevin
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Ive also had this problem.
    Its a firewall problem (at least that was the case for me). Either one (or both) of the pcs is firewalled. Check your settings.
    If you are using Zone Alarm, this prevents you from accessing files on the network.
  4. Banned
    Dec 2004
    SE4
    Yeah mate cheers im having all sorts of problems here.
    I cant network an XP Pro machine to an XP Home maxhine i just need a full gun what to do and click etc.
    I heard u go to start>settings>control panel>admin tools but theres no local service or something on xp home like there is on xp pro..
    If anyone knows exactly what to do please tell me..
    cheers 4 replies....guys
  5. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    did you set both up by Network setup wizard?
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
