I have a few DVD+RWs which I recorded from digital TV using my MiCO standalone DVD Recorder.
These are 16:9 format. The MiCO was set to 16:9 in its setup.
When you play them back on the MiCO or my Pioneer DVD player.. they play as anamorphic 16:9, automatically filling the widescreen TV.
Now.. I want to convert them to a DVD-R on my PC so I can add menus, edit out the ad breaks etc.
I can do this using Nerovision Express. I import the vob files from the DVD+RW and then merge them, edit out the ads, add a menu etc.. everything OK.
Then I come to burning.
If I leave Nero on the default (auto) then it burns as 4:3
When I play back on my TV, the picture is squashed into 4:3 and I have to start going into the TV menus to expand it to fill the screen correctly.
However.. If I set Nero to burn as 16:9.. It adds black bands to the top and bottom of my picture, in effect still creating a 4:3 image but with a 16:9 picture letterboxed inside.
Is there anyway to actually create a true 16:9 anamorphic picture?
Can Nerovision Express do this? If not.. what can?
DVD Lab
Tmpgenc DVD Author
DVD Workshop
Adobe EncoreRead my blog here.
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 12:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 05:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
