ok folks, here it is
macdvdbitrateparanoia 384kb
the new icon isn't yet in it which means you have to life for now with the old one :P
have fun 8)
Results 1 to 13 of 13
Thanks for the note. I've waited for this kind of Mac OS X native app for a long time.
Some quick observations:
I was stunned that it could draw a graph from a hours long DVD in only a few seconds. I was prepared for a much longer session. Where does it get the bitrate info so fast?
I then tried to open a "loose" .mpg file but it seems to only open an authored DVD. Could it be updated so that it could open also .mpg, .m2v and m1v files?
What about an ability to zoom into the graph so that one could evaluate it by the second? This would be useful when evaluating whether some blocky scenes get the bitrate they deserve.
It seemed to open only the first track of a DVD that iDVD 5 had burned. -
the bitrate information is stored in the .ifo files and therefor it only works with a authored dvd.
as for your idvd problem i can't help you cause i don't use idvd
Looks cool, if I could only get it to work. Every time I launch it, it unexpectedly quits. (G3, 10.2.8) I've downloaded it twice, once on AOL. the other on Safari. It installs fine, but never completes a launch.
you'll need to upgrade to mac os x 10.3 or aboveOriginally Posted by DeadLily
Oh, it only works on DVDs? Well, I was hoping that I could use it, to check my HDTV DVB Streams with it...
The link seems to be dead. Anyone know any mirror link? Or if you have it then upload it here in the forum.
Attach it when you post(under Upload image or file).
That didn't work (with Safari 3.1.1), which is why I asked. I can choose the file and it shows up as selected, but there's no way to actually upload it.
Okay, I figured it out. Needed to do the Submit without an intervening Preview.
macdvdbitrateparanoia-0.5.dmg.bz2 -
Thanks!
The preview button should be disbled after you selected a file...but it doesn't seem to work in safari.
Divx 7 released
By Peakr in forum Latest Video NewsReplies: 44Last Post: 2nd May 2009, 08:52 -
VLC 0.9.2 released
By Brazil in forum Latest Video NewsReplies: 0Last Post: 15th Sep 2008, 10:25 -
ImgBurn v2.4.1.0 released
By louv68 in forum Latest Video NewsReplies: 2Last Post: 1st Apr 2008, 13:18 -
VobBlanker 2.1.3 released
By jsoto in forum Latest Video NewsReplies: 12Last Post: 26th Jul 2007, 18:22 -
Safari for PC released
By dcsos in forum Latest Video NewsReplies: 6Last Post: 12th Jun 2007, 11:40
