  1. Is it possible to change the Recording Quality opption (mmc 7.1)
    Video BitRate,from 1.05 M Bit/sec to 1.15 M Bit/sec
    Motion Estimation Quality opption, from (?) to 99-95
    in Video CD tab without useing
    the custom settings
    thank you
  2. The HOW TO CAPTURE page on the web site has a section for the ATI All In Wonder, and it works for the AIW Pro 128 as well. Works great.
    Tim
  3. yes it does (mmc reg) but it changes the custum setting
    only , is there a way to change the pre set "VIDEO CD"
    from 1.04 to 1.15 M byte/sec ?
    can you help me ?
