First may i say thanks for this great software well worth the tenner....
I have done svcd to dvd no problems , so i tried a xvid avi , it keeps getting to about 14-15% and crashes out saying that there was an error with ffmpeg.
The funny thing is i have had problems with all different avi`s on different software and have not been able to convert one for ages...
I am running windows xp sp2 , and svcd2mpg v2 r3
could this be a codec issue , and are there any basic things i could check , reinstall before looking deeper into this error and putting the log up ??
Thanks in advance![]()
You don't need any codecs for SVCD2DVD. Some avi's may have some corruption, however, and this is why they may not convert. Basically i would need to test the file out...
In the first instance you could email me your log.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yeah this is the same thing thats happening to me and i'm using WinXP SP2 aswell. Used a load of other programs to try and convert the AVIs too and they either crash during the process or end up looking like they been through a blender lol
Which version are you using?Originally Posted by PlacidSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
2.0 RC3, i dont think its a problem with svc2dvd because im having problems with AVI conversions on all the programs i try, sometimes it even lock up my computer and i have to reboot
maybe my computer needs something .... maybe a lump hammer haha
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
G4 Keeps Crashing When Converting avi Files to dv
By elsiejazz in forum MacReplies: 3Last Post: 22nd Jun 2009, 05:24 -
ffmpeg keeps crashing when using DVD Flick
By djsuavetype in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2009, 14:06 -
DVD Decrypter crashing on rip error.
By mattstan in forum DVD RippingReplies: 6Last Post: 29th Oct 2008, 18:33 -
AVI.Net Crashing
By VirtualDoobMon in forum DVD RippingReplies: 2Last Post: 12th Jun 2007, 12:58
