http://www.cs.rochester.edu/%7Ebalazer/atsc/
epid - erase select programs in a multicast stream so that it will compress better
atrim - trim (edit) ATSC streams
ec - count the transmission errors in a stream
fix1088 - change the vertical_size_value in the MPEG-2 video sequence headers from 1088 to 1080. This will remove the grey bar that you see at the bottom of some 1080i broadcasts. Specify the video PID on the command line.
DVBtoATSC - DVB transport stream to ASTC transport stream remultiplexer
TStoATSC - transport stream to ATSC transport stream remultiplexer
TStoATSC3 - transport stream to ATSC transport stream remultiplexer with audio packet offset control
