I'm doing PAL VHS -> miniDV passthrough -> 1/2 D1 -> TMPEGenc -> DVD on a XP1800 Athon with 1GB.
1. Is Bilinear resizing the best resize to use when doing a simple 704x576 -> 352x576 resize considering speed, compressibility and visual artifacts?
2. In TMPGenc, I'm using 2-pass VBR and want to fit about 160 mins on a DVD. My last VHS transfer was 183 mins and it came out OK at 1/2 D1 resolution. I think the avg bitrate will be around 3300kbps but, with 1/2 D1, should the max bitrate allowed be around 8000 (I know you can go higher if you compress the audio more but I want to maintain compatibility) or 4000?
Code:SetMemoryMax (512) LoadPlugin("f:\windows\system32\Convolution3d.dll") # PAL VHS -> S/AV input passthrough on a miniDV -> AVI2 # splitting automatically after every 12000 frames # (8 mins at 25fps). SegmentedAviSource("Y:\Movie.avi") #SegmentedDirectShowSource("Y:\Movie.avi",25) # Using Panasonic codec, colourspace is RGB32 # With SegmentDirectShowSource, Codec is MS # and colourspace is already YUY2, but it # seems much slower to load. # Now 720x576 ConvertToYUY2(interlaced=true) #Crop(L,T,R,B) Crop(12,4,-4,-12) # Remove VHS switching noise & dark areas # Now 704x560 SeparateFields() odd=SelectOdd.Convolution3D(0, 32, 128, 16, 64, 10, 0) # same as vhsBQ preset even=SelectEven.Convolution3D(0, 32, 128, 16, 64, 10, 0) Interleave(even,odd) Weave() BilinearResize(352,560) #AddBorders(L,T,R,B) #Try and keep each a multiple of 16 for compressibility AddBorders(0,0,0,16) #Now 352x576
Yes, I'm frameserving. I thing resizing in Avisynth is faster then in TMPGenc. I remeber timing this at some stage because I had a 3 hour tape to work on. And I find it easier to setting everything up in an AVS file. I like using Ctrl-T (Insert Trim Set) to dump a trim range into VirtualdubMod's script editor and then pressing F7 to save and reload the AVS file back in VdubMod. Makes it very easy to see the changes.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
Batch Processing
By keefytee in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 7th May 2011, 04:41 -
Batch processing VHS to DVD Recordings
By jrobbio in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Nov 2008, 09:10 -
A few questions regarding capturing processing and archival of home VHS vid
By ido22 in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2007, 02:37 -
Batch Processing
By ruggie_uk in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 19th Jul 2007, 06:04
