I don't know if this is the right forum for this topic,
I made a couple of DVDs using TDA which has always worked for me until now.
DISC 1:
Had 2 volumes exceeding DVD 5 format (4.7GB)... so I used DVD Shrink so that i can fit both onto 1 disk. This disc works fine in PC Power DVD however when I load it in my set top dvd player, it only shows me the main menu (2 tracks)... If I select either track or play all, just freezes.
DISC 2:
Straightforward. Used TDA to create and burn the disc. Again, plays fine in PC, not so on set top players. This one doesn't even load the main menu.
For reference: I have a Pioneer and Toshiba DVD players and have tried both.
Am I missing something? Did I use wrong software? Did I chose wrong methods?
HELP
It could be any number of things, aside from just a bad burn, I've had issues with brands/type of media and also with discs that I've labeled. It's hard to say whats the cause of your particular issue.
Google is your Friend -
You can try some of the things I list here under number 2. https://www.videohelp.com/forum/viewtopic.php?t=253102
Here's what I found:
The culprit was the TMPGEnc DVD Author's writing engine which I have never had problem with earlier.
I took the same DVD FILES on HD and used Nero to burn the disc, voila! no problem at all. For some reasons I am getting an erro when I try to invoke the TDA's burner. DVDWriter.EXE ordinal not found or something in 'px.dll'
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 15:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 12:30
