  1. Member Soopafresh's Avatar
    Jan 2004
    A friend wanted some help over the phone... I was less than useless...
    2 Monitors hanging off of a Nvidia TI 4200
    Many apps will load in between -half of the app on the left and half on the right.
    Is there a setting in the Nvdia software to change this behavior?
    Is there a 3rd party app to stop the madness ?
    TIA
  2. go to the video properties and set it to "horizontal span". Then you have to make it remember the desktop setting.
    right click desktop
    properties
    settings tab
    advanced button
    Geforce Ti4200 tab
    Then play with those settings to make it work right.
    If that doesn't work........ I don't know how to fix it
  3. Member Soopafresh's Avatar
    Jan 2004
    Thanks ! I'll try it out.
