I back up my DVD using mactheripper 2.6.4 and then compress using DVD2ONEX and burn using Toast 6.
So why when i try to mount them again to watch on my MAC they won't mount.
The problem is that now even when i put in a normal DVD it won't mount Either.
Does anyone else have the same problems as me?.
Any help would be greatly appreciated
Thanks Scott
TAKE IT,BUT TAKE IT EASYYYY....
Toast will ask when you are done if you want to mount or eject the DVD when you are done burning it.
I have my CD/DVD settings turned on so when you put a DVD in the DVD player starts up.
Mark VMark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Does it actually make any difference if i verify my DVDs after burning.
Would it make a difference ?
What i don't understand is that my friend who burns on a PC never has these problems.
Maybe i should buy external burner that does + and - DVDs
Thanks scottTAKE IT,BUT TAKE IT EASYYYY.... -
Verifying only will let you know if you recorded errors on them but it would be too late to fix them since you just burned it.
Did you get to mount a DVD yet?
If not go into system preferences. click DVD & CD and make your changes there.
Mark VMark V
I changed the settings but still have the same problem.....
ScottTAKE IT,BUT TAKE IT EASYYYY.... -
I dont know what else to tell you.
Mark VMark V
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 17:57 -
Have you successfully backed up the Casino Royale?
By coody in forum DVD RippingReplies: 122Last Post: 27th Sep 2010, 02:21 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
Panasonic Blu-Ray player won't show Backed Up DVD or.....
By Scooter_NJ in forum DVD & Blu-ray PlayersReplies: 18Last Post: 3rd Sep 2008, 14:37 -
No main audio on backed up Blu-Ray BD-R
By ravo in forum Blu-ray RippingReplies: 2Last Post: 8th Aug 2008, 08:21
