I am looking for guides or tutorials on how to prepare the photos, images or any kind of stills in Photoshop for Video. Specifically: retouching, anti-aliases, etc. I tried to use Photoshop’s ‘.psd’ files in Premiere and After Effects, but the final video was not very good. The edges of the some stills were jagged when displayed at an angle, the text edges were also not very smooth. I'd like to use some photos and text for creating the Motion DVD menus.
Any help is appreciated.
did you select "optimize stills" in the project settings?
Which application has this setting? Premeire or AE.
Premeire
I will check, but I think it is always checked by default for every new project.
It sounds like you're using incorrect image sizes. If the images are going to be static, use 720 x 540 (ntsc). If you're using Premiere Pro and/or AE, you can use 4000 x 4000 resolution.
If you only used 720 x 480 and used a camera view in AE, you were probably a little too close to the image and therefore saw the actual pixels that make up the image. It's better to start with a larger image and use the filters in AE or premiere pro to zoom out or resize down the image.
Dissolving between stills
By solarblast in forum EditingReplies: 3Last Post: 11th Mar 2011, 10:11 -
Speeding up the showing of 60 stills?
By solarblast in forum EditingReplies: 4Last Post: 10th Mar 2011, 21:38 -
Best way to add stills to audio
By PrepositionJoe in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 04:53 -
Playing Stills and Video on a TV??
By reman in forum Newbie / General discussionsReplies: 7Last Post: 2nd Oct 2008, 14:27 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23
