Hi all,
I wondered if anyone could advise me on how to do the above in DVD lab pro please?
My aim is when a certain link is clicked, a screen will appear for 5 seconds then redirects to another screen.
Many thanks.
stokefan
A playlist that has a still and then your video might work.
George -
Have you tried selecting the menu you want to show and setting it's duration?
1. Select the menu you want to show as your "wait screen".
2. Select the "PCB" tab on the properties window.
3. The top item is "Duration" (inf. is the default, waits forever)
4. Change the duration to how ever many "seconds" you want it to wait on that menu screen.
5. In the "Connection" window connect your "Wait Screen" to the next menu or video you want it to go to.
You should put a hidden link to the next play item so your menu has something on it.
Problems with DVDLabPro
By carlmart in forum Authoring (DVD)Replies: 10Last Post: 23rd Jun 2011, 06:32 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 22:14 -
DVDlabPRO error
By Motinha in forum EditingReplies: 8Last Post: 4th Nov 2010, 23:01 -
avi2dvd menu is up only a few seconds.
By bman321 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 21:45 -
Menu problem: Only highlights showing in player
By ericf in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2008, 09:24
