ok upgraded to xp , even got uleads dvd movie factory to work (must to CLEAN install of xp)
downloaded and installed dazzle moviestar patch (4.24)
still cant see hardware? ie hooked up camera to rca jacks but device not seen (yet on boot up dazzle dvc new device found ) shouldnt the 4.24 install the drivers? is there a seperate place for drivers? did all web site (dazzles ) said to do.??
ideas?
thanks
I've got XP and dazzle DVC and I pretty much did what the instructions said:
1. Put driver disk in.
2. Cancelled setup.
3. THEN plugged in USB device (hardware then detected)
4. Pointed driver install to CD drive.
5. Installed MovieStar off CD (4.22)
6. Applied 4.22 to 4.23 path.
7. THEN applied 4.23 to 4.24 path (XP Patch)
It should detect the hardware regardless of order of software install.
What about USB in general.... can it detect another USB device if you plug it in?
It could be the device might already be in your harware list with busted drivers. Remove it if it is...
thanks for your reply i will try tonight, been away for few days
from what i recally the Dazzle usb device is DEtected by windows xp
but in moviestar it is not.
will relay more information later tonight
thanks
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 14:14 -
Pinnacle Dazzle 'DVC 170' Woahs...
By synthecypher in forum Capturing and VCRReplies: 4Last Post: 3rd Jun 2010, 21:02 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 09:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 06:18
