I HAVE CONVERTED AND BURNED TWO AVI FILES TO DVD WITH WIN AVI CONVERTER BOTH DVDS START IN MY STAND ALONE PLAYER AND A PICTURE COMES UP BUT IT THEN FREEZES. FUNNILY ENOUGH I AM ABLE TO SCAN AND GO FROM CHAPTER TO CHAPTER.
CAN ANYONE EXPLAIN WHAT THIS IS AND WHY IT IS HAPPENING AND HOPEFULLY GIVE ME A SOLUTION SO THAT I CAN FIX IT.
Please do not post in all caps, it is considered shouting and bad forum ettiquette.
As to your problem, have you checked wether your DVD player will play DVDr (+ or -). You can check to see if yours is listed hereThere are 10 kinds of people in this world. Those that understand binary... -
Firstly, my apoligies for the caps.
Secondly, I just checked if my player is compatable with DVDR+- and it is compatable with DVDR+ which is the type of disc I am using. It is a Pioneer DV-525.
Any other tips would be appreciated -
Well, freezing is a typical symptom of media/player incompatibility. You say your player should be able to play DVD+r, but have you got good quality media. Chevk the list again to see what brand media others have had succes with and try one of them.
I would say the problem is that your player just doesn't like the media brand. Three dvd players in the house.....two will play a backup I created, the other will play, but has a lot of distortion in the picture. Try playing it in a different player. If it plays fine, try switching brands.
Oh, I should say this. The backup was burned on a Maxell DVD-R made in Japan, so even high quality media is not guarantee of playback.TANSTAAFL -
Thanks for all the great tips........the only thing is that I have backed up DVDs on the same media and they work fine on the same player. I'm not sure but this would suggest to me that the media is fine although they are only fairly cheap.
AVI file won't play via stand alone DVD player
By 3lutz3toe in forum MacReplies: 2Last Post: 24th Dec 2009, 06:37 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 03:00 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 17:53
