When I make VCDs the quality isn't as good isn't as could as I was hoping for. It might just
be that I'm overestimating the picture but I'll see if I can get it better anyway. The
problem is the playback has sort of yellow tinges fading in and out and general light
quality not very good. When there's a lot of action on screen the frames aren't as smooth as
I expected a bit like a slight blur. I use Divx DVD ripper to encode vob files to Mpeg-1
and have tried tweaking some of the options to no avail or it says it won’t be VCD
compliant. Though I doubt this has any bearing as I've checked them before burning I'm using
Ulead DVD MovieFactory 2 and MediaStudio Pro 7 to burn them because Nero only gets to 100%
encoding and doesn't do anything afterwards. I've tried different programs to make these
files but the quality is the same and when I try to use Nero it says it needs to re encode
them to become compliant. I know a little on the subject overall but I'm still a beginner in
a sense! Again this is probably irrelevant but I'll cover as much as I can so I don't need
to keep re posting. I use DVD Decrypter and DVD Shrink though I try to mostly avoid any
compression with the latter, mainly just to get just the bits I want. Basically I just want
to improve the picture quality to get rid of the elements I mentioned earlier; I don't
expect anything better than VCR quality or even close to DVD. Any help would be much
appreciated! While I'm on the subject I've been overburning CDs to fit around 85 mins or so
on each disk with 800mb disks but need to do the former because my LITE-ON CD-RW SOHR-5238S
doesn't recognise they're over around 702mb. Is there anything besides the firmware upgrade
that I've all ready done to make it recognise the real disk size? I only mention this
because some programs refuse to let me overburn. By the way as for the Ulead products
they're only trial products so I prefer to go the freeware option will look at other things like shareware, etc.
other forms. Again sorry this is so long! Any help would be much appreciated!
If in doubt, Google it.
Problems encoding a quality streamed video
By Berek Halfhand in forum Video Streaming DownloadingReplies: 7Last Post: 13th Feb 2009, 21:24 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 10:08 -
AVI to DVD quality problems
By Stetsondolly in forum Video ConversionReplies: 20Last Post: 11th Feb 2008, 20:23 -
Camcorder-PC quality problems
By Brazil-Ben in forum Capturing and VCRReplies: 2Last Post: 5th Oct 2007, 17:45 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 22:53
