Ok I converted a file that had to NTSC, 23.976 (internally 29.97) with 3:2 pulldown with playback, and I checked do not frame rate conversion (I used tmpgenc for my conversion). After the conversion I realized the audio is off synch, the video i converted was origionally 50.00 fps. I tried using besweet to fix the audio after i De-multiplexed it with tmpgenc but still no luck. Can anyone help me figure this out and get the audio and video back in synch? Thanks
-spiral
50 FPS? I'm a bit confused by that. Is the original a progressive deintelaced, 25 FPS file that is misread or something?
You are in breach of the forum rules and are being banned.
/ Moderator John Q. Publik
audio problem when converting
By Stevex70 in forum Video ConversionReplies: 0Last Post: 25th Mar 2011, 15:56 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 22:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 05:52 -
No audio converting flv
By holywoodhawk in forum Video ConversionReplies: 0Last Post: 11th Aug 2009, 23:38 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 05:55
