Hello. I am authoring an SVCD disc, with "interactive" menus, as well as both non-anamorphic (standard svcd resolution) and anamorphic (dvd resolution) widescreen conversions.
I have calculated that all of my MPEG videos and stills combined will add to approx. 820MB.
This is ~20MB over the limitation of 800MB of an 80min CD-R. (Nero would say its about 82 minutes)
My CD burner is capable of doing overburn, and i have used it to burn 26mins or so on 24min discs.
But ... my question is... If there is an extra 20MB of data at the end of the disc, is there any possibility that my dvd player(s) would have difficulty reading this extra data?
asdf
CD's are cheap try it. Burn it at the lowest available speed for the best results though.
Well, I guess you have to waste the encoding time.snappy phrase
I don't know what you're talking about. -
Most CD media should have enough space for you to overburn this much, but I can't guarantee that every brand you buy will have enough extra space. You could always buy 90 minute CD-Rs. They're not technically allowed by the CD specs, but just about every device on the planet can play them anyway. Assuming you overburn correctly there should be no playback problems. You need to burn as slow as possible if you overburn a SVCD disc. Anything above 4x speed may fail during overburning.
Do 2x if you can.
Your original post concerns me a little as you may be deviating too much from SVCD specs to have a disc that will play. SVCD doesn't really support interactive menus, at least not like DVDs have. DVD resolutions are invalid for SVCD, although most players aren't too picky about resolutions. Good luck. -
Originally Posted by jman98
The slowest burning speed my cd burner is capable of is 4x, so i will use that.
the anamorphic conversion is for players that are capable of playing it. (2 out of 3 of my dvd players can play it properly)
The non-anamorphic mpeg's will be svcd compliant and should therefore be able to play perfectly on virtually any svcd capable player.
I am using VCDEasy to make the menu...
Thank you for the reply...
Perhaps I'll do some tests to see how much I can push onto an 80min disc...
I was thinking of buying these... I can't find any info on the site about shipping time/cost.
I dunno. I'll just do the overburn of 20mb extra and i'm sure it will play fine.asdf
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 01:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 09:08 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
