i have been trying to buy this software from their site and it wont let me,it says my aol address is invalid,is there anywhere else to get this?
Results 1 to 26 of 26
Why don't you wait for January ? then they will have the new version which will also include MPEG2.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i cant wait till the VErsion of Panasonic comes out i hope it is a bit faster
just a bit ?
takes around 7 to 8 hours with the first encoder
I hope they are gonna do atleast 50% boost in performance
Best Regards,
Sefy Levy,
SWEEEET! A new Panasonic encoder!!
Baldrick do you have any info on it - are they going to add some much needed features (such as 'resize') ??
If they need some beta testers let me know - I'm a big fan of the current encoder (via a frameserve from VirtualDub) -
Next month we'll all know the new details
Best Regards,
Sefy Levy,
Every one says Panasonic Mpeg Encoder is the best when it comes to quality. So I tested it, but didn't find noticeable quality improvement. Any suggestion for settings to encode better?
Lumpya1a: when you see people talk about software like Panasonic or CCE it was either purchased or *found* on usenet. Please don't ask me for more details - the rest is for you to figure out.
My suggestion to get on USENet is http://www.giganews.com or http://www.usenetserver.com -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
ok the skinny is this: it's a bit quicker than TMPGEnc - it does good solid VCD standard MPEG's with very little (if any) block noise. Thats why people like it.
There are very few settings to change - and you can't resize but the noise reduction works v. well.
It's not that it's MUCH better than anything else - it's just easier and a bit quicker than other choices. -
Stinky, just a minor correction, it is defenetly not faster! what takes me 3 hours in TMPGEnc, takes around 7 hours to 9 in Panasonic, but it's quality is much more impressive, you rarely get any visible blocks, even in high motion scenes.
Best Regards,
Sefy Levy,
So which one has better quality overall? TMPGEnc or Panasonic?
I only dream in black & white...
MSN: paschendale@gmail.com -
Quality ? Panasonic, i'd prefer it any day.
Quality+Performance ? TMPGEnc without a doubt.
I think with latest TMPGEnc versions, the quality part is a very thin line, it is barely noticable, althought at times, in TMPGEnc there are more blocks then Panasonic, and I think the Colors in the Panasonic are more vivid then TMPGEnc, and more bright.
Best Regards,
Sefy Levy,
Sefy?? really - for me an 2 hour conversion in Panasonic takes 3 or more in TMPGEnc - on my system it runs faster - though I should add if I'm doing a high-end DivX conversions in TMPGEnc I have it on HIGH or HIGHEST so maybe thats the catch.... but I have to do that to make the block quality equal to Panasonic. Go figure
Glad you lot have got to test it,I D\L the demo and all you get is a 30 second encode barely enough time to get by the credits and when used on a clip with no credits barely enough time to judge quality or speed! best part is it's a months trile of 30 sec encodes what a joke.
Does anybody know if it's compatable with Nero? -
100% --- It makes standard VCD's - PAL or NTSC -
hi everybody
I use Panasonic Encoder & Nero 5.0 all the time.
No problem at all. -
Is there an encoding time difference between using the Panasonic MPEG-1 Encoder through FlaskMPEG and using the Standalone Panasonic MPEG-1 Encoder?
Also, what's faster to make a (X)VCD. TMPGEnc or Panasonic?
Thanks,
No, I think they are both just as slow, although it's possible the Standalone is faster, cause I mostly used the Plugin with Flask or DVD2MPG.
If you are going to do Non-Standard, then you better use TMPGEnc, Panasonic doesn't handle that very well.
Best Regards,
Sefy Levy,
AnonymousGuest
Personally I would not bother with the panasonic encoder, I think its a pile of sh*t. The quality when converting from DV to mpeg1 is so bad(blocks everywhere & problems with sound sync). I would recomend Tmpgenc as its the best by a long long way in my oponion
And as far as speed, if you have a pent 4 or amd xp series cpu tmpenc is faster than panasonic.
actually came home and did a test with panasonic since I haven't used it since upgrading my cpu, with pearl harbor disk to as the test rip Tmpenc took 54 minutes to encode on high setting, panasonic estimated 3 hours about 10 minutes into the encode on high setting, I stopped the test. Maybe the new Panasonic will take advantage of SSE, I still use panasonic for troublsome divx files as it seems to be more tolerant when tmpenc fails.
Maybe thats why you and I disagree on the speed of Panasonic vs. TMPGEnc - I only use the Standalone while you use the Plugin.
I also agree with you that for non-standard VCD's you shouldn't use Panasonic - I've tried some xVCD setup's in Panasonic and had trouble burning them. -
this test was with the stand alone version, and it was the pearl harbor disk 2, kinda hard to read that in my last post, a 47 min segment.
Stinky, so you saying the Standalone is faster ? well, atleast that's a good thing, the Plugin was pretty slow no matter what CPU you use.
Best Regards,
Sefy Levy,
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 10:16 -
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2010, 23:32 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 14:40
