  1. i'm having some hard time with this burning a mpeg on a freakin dvd. In order to burn a mpeg with 2 cds you have to join them together rite? so i did that and try to add it in to dvd+r with nero and it took freakin 5.0gb and the file is only 1.57gb EK! i tryed alot but i don't know what to do man. please help me figure out a way to add mpeg on to a dvd without going over 5.0gb thank you please.
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    TMPGENC DVD Author
    You are in breach of the forum rules and are being banned.
    / Moderator John Q. Publik
  3. yes i also tryed that. and it said that this is not a dvd fromat. the size is diffrent. i have no idea what to do after that
  4. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    What is the framerate/frame size/ audio encoding of your files? If your files are being rejected, you will need to reencode them or adjust them so they fix DVD specs. Try using the reglar TMPGENC encoder.
  5. DVDLab will author it, with a warning if the files are different, but it will still author it.
    Cheers, Jim
    My DVDLab Guides
