I have a Toshiba DVD recorder in my Compaq presario Laptop. It supports DVD+R/RW DVDs. I was trying to write DVD-R and was failing with the obvious error of not recognizing the DVD.
Is it possible to Wrier/Record DVD-R with DVD recorder that supports DVD+R/RW format?
Thanks,
Sum
What's the exact model number of our laptop and burner? Usually if a drive only supports one format, it will not be able to write to the other, like you discovered. I do remember reading that some drives could be made to use both with a firmware upgrade; maybe this is possible for your particular burner.
You are in breach of the forum rules and are being banned.
/ Moderator John Q. Publik
HELP PLEASE!! Can i record an AV channel on DVD recorder HELP PLEASE
By Lilman02 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Apr 2010, 15:55 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 13:37 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39 -
Can a HDD MiniDV record a DVD by connecting with a DVD player/recorder?
By coody in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Jan 2008, 10:01 -
Help - using dvd recorder to record off dvd player
By AlastairSim in forum DVD RippingReplies: 5Last Post: 26th Jan 2008, 13:43
