Hi guys,
I recently decided to backup "Out for Justice" an old Steven Seagal movie. The DVD was a DVD5. I backed up the disc to the Hard Drive using Clone DVD 2 and it took approx. 15 minutes. After burning the disc I decided to see if the backup would copy to the hard drive any quicker and sure enough it did (6 minutes). Does anyone know why this is the case? It seems strange since no transcoding was required.
(1) The original was double layer (unlikely since no transcoding/shrinking was needed)
(2) Many DVD drives limit the read speed of pressed DVD-ROMs to avoid excessive noise/vibration.
(2.1) The read speed is limited by the following: Hardware, Firmware, software (can sometimes be used to force faster/slower read speeds, such as Nero DVDSpeed - keep in mind not all DVD drives may work with such software), and the condition of the disc being read (scratched/dirty/fingerprints).
A possible test: Try copying/reading a DVD+R disc that has been bitset to DVD-ROM.
Work around: Use software to (force) speed up the drive (2.1 above), Flash the drive with a firmware that supports faster read speeds of DVD-ROM (hacked firmware will VOID warranty).Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Originally Posted by jimmalenko
That's what i was thinking also but i wanted to see if anyone else said it first
I'm gonna test this out once because i have quite a few dvd5's....
Best dvd9 to dvd5 backup software
By MrBobFloyd in forum DVD RippingReplies: 7Last Post: 30th Nov 2010, 21:29 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Possible tool from jdobbs for blueray to dvd5/9 avchd backup.
By freebird73717 in forum Blu-ray RippingReplies: 12Last Post: 30th Sep 2008, 02:18 -
Backup DVD9 NTSC to DVD5 NTSC in a PAL environment
By kroppkaka in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2008, 03:00 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 11:05
