  1. Ok so i have 3 seperate movie files each works perfectly on my computer, however when i use svcd2dvd to make a vts the third file comes out skipping with no audio on it. Heres the log
    "Starting SVCD2DVD: v1.51.2.0
    Begin time: 9:14:10 AM
    ******** Ripping BIN images to get mpegs (VCDGear )
    VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
    Testing and quality control by MACKerMD
    Language: English
    Version: 3.50 - Jan. 1, 2003
    Translation by: Dracore
    processing method :: (bin2mpg)
    .bin src(In) -> D:\temp\svcfodler\nfr_ray3.bin
    .mpg dest(Out) -> D:\temp\svcfodler\nfr_ray3.mpg
    [nfr_ray3.bin] Detected sector size: 2352
    # 0%
    #searching...
    Track 1: 833379428 bytes [06:52:17]
    #searching...
    1 track(s).
    Setting read size to: 2352
    Setting write size to: 2324
    # Track 1 -> writing...
    # OK!
    (Total size: 805MB, Duration: 00:04:59, Rate(MB/Min): 161.13)
    Analysing File: D:\temp\svcfodler\ray1_DVD.mpg
    ++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
    ++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
    Analysing File: D:\temp\svcfodler\ray2_DVD.mpg
    Analysing File: D:\temp\svcfodler\nfr_ray3.mpg
    ++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    -->Processing 3 mpeg files
    ############### New MPEG File ###############
    Type: SVCD
    Horizontal Res: 480
    Standard: PAL
    Audio SampleRate: 48000
    - Leaving ray1_DVD.mpg alone. File has Nav Packs
    Type: SVCD
    Horizontal Res: 480
    Standard: PAL
    - Leaving ray2_DVD.mpg alone. File has Nav Packs
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    (Total size: 794MB, Duration: 00:04:05, Rate(MB/Min): 193.88)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 80MB, Duration: 00:01:07, Rate(MB/Min): 71.19)
    ******** Trimming start of video ES
    - Nothing to do.
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [???] File D:\temp\svcfodler\nfr_ray3_DVD.mpv looks like an MPEG Video stream.
    INFO: [???] File D:\temp\svcfodler\nfr_ray3_DVD.mpa looks like an MPEG Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (D:\temp\svcfodler\nfr_ray3_DVD.mpv)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 480
    INFO: [???] Frame height : 480
    INFO: [???] Aspect ratio : 4:3 display
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 2450000 bits/sec
    INFO: [???] Vbv buffer size : 229376 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: Audio stream c0 (D:\temp\svcfodler\nfr_ray3_DVD.mpa)
    INFO: [???] MPEG AUDIO STREAM: c0
    INFO: [???] Audio version : 1.0
    INFO: [???] Layer : 2
    INFO: [???] CRC checksums : no
    INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] Mode : 0 stereo
    INFO: [???] Mode extension : 0
    INFO: [???] Copyright bit : 0 no copyright
    INFO: [???] Original/Copy : 1 original
    INFO: [???] Emphasis : 0 none
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 2720800
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 72339
    INFO: [???] STREAM e0 completed @ frame 72339.
    ++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
    INFO: [???] STREAM c0 completed @ frame 125714.
    INFO: [???] Multiplex completion at SCR=271558070.
    INFO: [???] Video e0: buf= 237568 frame=072339 sector=00363535
    INFO: [???] Audio c0: buf= 2080 frame=125714 sector=00041823
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 729306216 bytes
    INFO: [???] Sequence headers: 6252
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 72339
    INFO: [???] No. Groups : 6252
    INFO: [???] No. I Frames : 6252 avg. size 32636 bytes
    INFO: [???] No. P Frames : 18534 avg. size 14005 bytes
    INFO: [???] No. B Frames : 47554 avg. size 5587 bytes
    INFO: [???] Average bit-rate : 1933600 bits/sec
    INFO: [???] Peak bit-rate : 2312400 bits/sec
    INFO: [???] BUFFERING min 15 Buf max 224813
    INFO: [???] AUDIO_STATISTICS: c0
    INFO: [???] Audio stream length 84480484 bytes.
    INFO: [???] Syncwords : 125716
    INFO: [???] Frames : 125716 padded
    INFO: [???] Frames : 0 unpadded
    INFO: [???] BUFFERING min 15 Buf max 683
    INFO: [???] MUX STATUS: no under-runs detected.
    (Total size: 803MB, Duration: 00:04:03, Rate(MB/Min): 197.99)
    Analysing File: D:\temp\svcfodler\nfr_ray3_DVD.mpg
    ******** Creating DVD Folders...
    Creating VTS #1
    SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    -->: DVDFolders creating VTS
    -->: VTS 01
    STAT: Processing C:\Program Files\Badgersoft\SVCD2DVD\dummymenuPAL.mpg...
    STAT: Processing D:\temp\svcfodler\ray1_DVD.mpg...
    !!!: GOP is not closed on cell boundary (may be non seamless)
    STAT: Processing D:\temp\svcfodler\ray2_DVD.mpg...
    STAT: Processing D:\temp\svcfodler\nfr_ray3_DVD.mpg...
    ADDING PRE COMMAND!
    ADDING PRE COMMAND!
    ADDING PRE COMMAND!
    ADDING PRE COMMAND!
    WARN: audio sector out of range: 8196 (vobu #636, pts 33071828)
    WARN: audio sector out of range: 8231 (vobu #637, pts 33125828) "
    And the audio warning is repeated many more times...
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try v2? If there are issues with v1.5, v2 usually resolves it. Otherwise you can try playing around with the options in v 1.5. uncheck the ffmpeg option, for example.
  3. Well i got v2 but similar problem.
    I think it may be because the first 2 files are PAL and the other which doesnt work properly when copied is NTSC.
    Would this be the reason there is conflict ? Fixable? If i copied the first 2 seperate to the last one which i could make in another VTS folder maybe. I might try that now.
    one more thing, the last 2 movies i made after this the 1st second sticks and you need to FF to get past it to the next chapter then RW back to the start. Funny cos it only occurs on my main dvd player and not my comp or PS2.
  4. Success, i was right... 5 blank dvds later were in business Now to try some avis
