Hi there,
my dvd burner is supposedly a Dual DVD +/- Burner(I have an averatec 3200series) and I'm using verbatim dvd+r dl's and I wanted to burn home videos onto it with menus and stuff, and the computer doesn't even recognize the disc is in there! I tested it out first with a regular 4.7 and it burned but obviously left some stuff out, but to get it all I thought it would work with this double layer disc and now the computer doesn't acknowledge its existence... am I missing something here? any input is appreciated! thanks!
Results 1 to 10 of 10
depends what software you use to burn.
try using dvd decrypter v3.5.2.0 and use iso read,iso write.then try to burn that way with dvd decrypter,its free,and youll see it in the tools section
<-------------tools section
are you using xp,or another OS.?
my kids pc,doesnt recognise +r discs,on the burner they have,but if you stick the disc in and try to burn,it works,just seems to be a big in her OS.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
I've been using roxio drag to disc... I forgot to mention. and windows xp... it worked fine with the other dvd-r... I will see what happens here... thanks
check the specs of your laptop burner with dvdinfopro
dual does not necessarily mean dual layer
it often refers to dual format +/- -
ARGH!
Roxio drag-to-disc? So... packet writing yeah?
Packet writing is the illicit and unholy love spawn of Satan and Dolly Parton's left tit. -
Funny, before you posted this i was thinking about adding a "BAN ROXIO" logo to my avatar!!!Originally Posted by MpegEncoder
I just saw another post yesterday where someone could not figure out why decrypter or something was not working until they got rid of "roxio" then it worked
And i hated their programs way back when cd-r's were the only thing being done
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 05:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 12:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 20:47
