sadly i cant find this using search so i need to make a new thread - i have put some files into mpeg video wizard have added fades - now i want to export them all as one big file - put i do not wish to re encode.
i want told this was possible but i cant find a save button anywhere! can some please point me in the right direction!
thanks!
mik x
Results 1 to 9 of 9
This pic is taken from the MVW help files.
To Export a movie, click the Red button in the lower right hand corner or click the Export button in the Toolbar. Note: if the video files you are combining have different specs, some (or all) will have to be re-encoded. -
the video files have the same specs - the save button you give me seems to save the project but it doesn't make a new mpeg file.
Check my edited post above. This should help. Also, the the Help files with MVW are quite good.
thanks for your help but i don't think it's exactly what iw as after - the video specs are exactly the same, taken off the same disc. i put them together, add a couple of fades and adjust the brightness in them and when i click the export button the only option i find it to re encode - obviously i want to avoid this if possible.Originally Posted by Epicurus8a
thanks again for your help. -
As you have added transitions, those portions (and those portions only) will have to be re-encoded. The bulk of your movie will not be re-encoded. Depending upon the bit rate, you may notice a slight decrease in quality during the transitions.
ah ok, i understand - since i adjusted to brightness of the clips does that mean the whole thing has to be re encoded?
thanks for all your help - much appreciated. -
Gee, do I feel silly. As I hadn't tried that before, I quickly setup a test and found that it does have to re-encode after adding the filter. Duh!!!!! The portions you have touched shouldn't re-encode. And that makes perfect sense after all, the video is being tweaked.
it's re encoding the video now - 47 minutes is gonna take:
8 hours
one ot be left on all night i feel, i wonder what the output file will be like...
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Help with Camera, Capture, Encoding, and Saving.
By shane123 in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2009, 20:24 -
How to use Mpeg Video Wizard
By windranger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 08:24 -
Saving files in original quality in MPEG Video Wizard DVD
By guy24s in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2007, 16:30
