Hi, i just bought the liscense to the DVD2SVCD software. I had to wait 2 days before posting here, which was ******* gay by the way, and here i am.
I have a couple of questions however. I have a whole bunch of files that will only fit on a Dual Layer DVD, the ones with 8.5 GB. I happen to be a lucky guy with a Dual Layer DVD burner and Dual Layer DVD's. Is it possible to burn on a dual layer DVD with DVD2SVCD?
Another question, when DVD2SVCD authored the entire DVD to a folder on the HD, can i just drag and drop the files on the DVD with, for example, Nero?
Yet another question, i created all SVCD-compliant files. When i use the "don't change audio rate" function, does SVCD2DVD 1.5 leave my files alone ie don't re-encode them? Also, how long would a full DVD with 5 SVCD files take to author on a P4 1.7 GHZ machine with 512 MB ram?
Last question, DVD2SVCD 2.0b is really cool, but a little too beta-ish for me. I really like the audio for menu option though. Can i also do this with the menu option for DVD2SVCD 1.5?
-Dick
Have to say for your 1st post i really dont think you should be swearing and offending people on here?
Im sure Chrissy will answer all your questions but maybe less of the attitude? -
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Just used it as well, worked fine. I've used an older version of copytodvd for 2yrs now. The only thing that I don't like about the new version is all the popup menus (create photo/dvd/cd/etc), would like if that could be disabled and just the progrma itself would appear and there you can choose which option like in 2.0xxx
What We Do In Life, Echoes In Eternity....
Pinnacle 12 DVD Menu question
By thejigsawman in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2011, 12:39 -
How to back up two main movies of different version with selection menu?
By coody in forum DVD RippingReplies: 3Last Post: 8th Jan 2008, 16:41 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 22:06
