I have a Pioneer 107D burner. I never had an issue with 4x media but now I am trying to use 8x media and most brands will only write at 4x. I checked all of the obvious settings, has anyone else ever had this problem?
I use DVD decrypter and even then when I load the blank (a 8x blank), the program says "speeds supported: 1x, 4x".
Aggrivaiting.
Writes:
DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW
DVD-R 8x*, DVD-RW 4x*
DVD+R 8x, DVD+RW 4x
CD-R 24x
CD-RW 24x
Not sure what you are using, this is all I could find.What firmware are you using? -
Whatever firmware which it uses during the first install.
I havent had problems in the past with 8x media, it's like all of the sudden these new issues arise.
I used to use 8x DVD-R DVD's by Supermedia. The shiney ones, not the matte silver finish and I can't find them anymore.
I bought 200 DVD-R 8x disc's and they dont work. I bought another 25 of Memorex and those write at 4x, I also just got 25 Dynex and those don't write any faster than 4x. -
There's no problem with burning @ 4x. IMHO, I'd stick with 4x for 100% standalone DVD player comptability. The time difference is but a few minutes — just crack open another beer while you wait. ^__^
MJ(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
(2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
Sounds like junk media not supported by the firmware.
The media that once WAS supported now doesnt write @ 8x.
So media written @ 4x is more stable? Wow, anyway you can confirm this? I dont mean to dog your advice but I like to read up on stuff. -
It's not necessarily true that burning at 4x is more stable. The 107D is quite capable of burning at 8x with very low error levels on the right media, like TYG02 or MXLRG03.Originally Posted by joed1228
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 21:47 -
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 18:37 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 01:40 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 12:58
