Hi, I am new here. Maybe you can help me. I was using TMPGEnc to convert QT MOVs to MPG. It worked fine until I upgrade my system to QT5. Now, it freezes when the plug-in for TMPGEnc is installed and I have no sound converting MPG to MPG files when it is not!
I do not have QT4 installer anymore so I can not go back. What should I do? Is there a version of QTreader that works with QT5.
Thanks in advance.
try searching at http://www.google.com and you might find the installer for QT4
and there is this other encoder call MEGAPEG but it has one of the worst quality encoder
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 02:59 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 13:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
