Ive recently been burning away putting 2 movies on 1 dvd to save discs only know i would like to split them up from the video_ts folder which has them in .vob files. I tried just taking out the selected vobs and putting them in nero but as i thought it came back with an error. Any thoughts?
Also does any1 know if svcd2dvd will incorporate avi - video_ts
cheers
1) If your movies are in seperate VTSs then vob2mpg will give you mpgs for each movie.... see https://www.videohelp.com/forum/viewtopic.php?t=252033
2) v2 does yes.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
you could also use dvshrink and reauthor just the movie you want, then do the same with the other etc.
How can I rip DVD to AVI and make each chapter a seperate file
By mikeyshine in forum DVD RippingReplies: 10Last Post: 23rd Sep 2011, 15:02 -
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 10:12 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 13:56 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26 -
2 movies with seperate pagew for chapters of each movie possible?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 28th Aug 2007, 08:10
