HI,
i've made a DVD using DVDLabPRO which has exceeded the amount of 4.7GB.
the DVD is 6.4GB.
This has never been a problem before as i would use DVDShrink to compress it to the correct size.
However of late evertime i make a DVD in DVDLabPRO and put it on DVDShrink it doesn't load the files, it just has an error, which says one of the .VOB files is damaged and cannot continue.
can anyone help me with this?
Many Thanks
Will the whole video play in your PC player? You could try rebuilder, but if there really is a problem with an ifo or vob, rebuilder will not work either.
Have you tried to uninstall/re-install DVD Shrink? Sometimes this clears errors that i have encountered.
Have you updated your copy of DVD Lab Pro recently (or ever) ? There was a version that produces incorrectly sized VOBs (based 1GB on 1000 bytes, instead of 1024). This has been fixed with a free patch. Incorrect VIB sizes could throw Shrink off.
One final comment - you will generally get much better quality if you encode your assets to the correct size in the first place, rather than Shrinking after the fact. Just my 2 cents. -
were can i get hold of this patch for dvdlab pro as i can't find it on the website.
use the "History" link on the left:
http://www.mediachance.com/dvdlab/index.htmlGeorge -
thanks
that did the job.
that's all it needed an update. Didn't notice there was one available till you mentioned it.
Cheers
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2010, 00:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 18:17 -
DVDshrink error
By rubberman in forum ComputerReplies: 1Last Post: 3rd Sep 2008, 23:51 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
