I have 2 small problems with the menu and chapters after using TSCV and burning with blindwrite.
first the menu problem: For som reason something cut the 5-10% of the menuscrens so theys all black. its only a visual error in the manu and the menu works fine and movie shows fine but its uggly..
the chapter problem is not a huge either but it would be nice to fix it. while playing the movie i cant ust >| to skip to next chapter. I can use |< to skip to previous or i can use the numbers to select a chapter. if the |< works fine why wont >|?
I use TSCV 0.82 rel 4, new VCDimager to author and blindwrite to burn.
Maby can i be a hardware problem? my player is a Hitachi 515E
thnx
I don't know about the Menu problem, but the Next/Prev button problem doesn't make sense, cause I know it works, there must have been some error somewhere, I would recommand you send the XML and LOG file to the author of TSCV, and he will be able to assist you directly.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
dont know why but newest TSVC (rel 5) fixed the skipping problem.
Well, I am the slime from your video.
Oozin' along on your livin'room floor.
Chapter list Menu problem with MultiAVCHD
By Jijital in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Feb 2012, 16:29 -
Play All option STILL goes to menu after each chapter
By stevencarl in forum Authoring (DVD)Replies: 1Last Post: 5th Oct 2011, 13:17 -
Menu chapter and/or whole movie.
By rpvliet in forum Authoring (DVD)Replies: 2Last Post: 21st Aug 2011, 12:10 -
Return to Title - NOT Chapter Menu - HOW?
By jlrm365 in forum Authoring (DVD)Replies: 7Last Post: 13th Mar 2010, 21:15 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20
