I am in the US and I have several PAL authored dvds that I cannot play on my dvd player. So I purchased a Desay dvd player that plays PAL authored dvds. I have hooked the Desay up to my tv and made the adjustments (eg into menu to settings to PAL) and I am still getting a distorted picture. What am I doing wrong and better yet, how can I fix it.
I have taken the advice of some that encouraged me to buy a PAL/dvd player vs converting the PAL to NSCT. Can someone pleae help me to make this work where I can get a decent picture and sound on this player?
Is it the palyer, the television or both? Any information would be greatly appreciated. TIA
What do you mean by distorted ?Originally Posted by illyad
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
The best way to do this , would be to set the DVD player to region free, NTSC and see if the player will convert the signal, what you are doing Is out-putting Pal, and your TV is NTSC. I dont know anything about your Player but I bet that is the problem. if it doesnt work I know the Philips DVP642 will work.
PAL coded DVD in U.S. player?
By Goodluck Jonathan in forum Newbie / General discussionsReplies: 50Last Post: 16th Apr 2012, 23:27 -
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 18:56 -
Best region free PAL DVD player for $50 - $70
By jamest in forum DVD & Blu-ray PlayersReplies: 9Last Post: 26th Jun 2009, 04:53 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 07:40 -
Looking for a PAL DVD player
By obolon84 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jan 2008, 07:31
