    Dec 2001
    Australia
    Hey
    I get this message on alot of my music vidz. I use Roxie Easy CD Creater 5 .
    The File C:\Warez\Music Vidz\ Geri-Hot.mpg will not work in a VCD player to make this file compliment you will need to use a MPEG encoder that has Video CD Support.
    It happens on some MPEGS, Avis, MPGs/ And yet some work, some dont. I dont know what is wrong. PLease help me.!
    Jigger
  2. Some music videos, especially downloaded one, are not standard VCD, so roxio will not accept anything else but standard one.
    1. You can demux then mux those files that aren't standard with TMPGenc then burn them again.
    2.You can use other softwares to burn your VCD such as Nero and uncheck create standard compliant CD.
    Hint: burn in CDRW to check if your DVD can play all files first.
