i dl this dvd that contain 10 episode in 1 dvd. each episode is about 42 min in length. i convert a similar series(lengthwise) and was only able to get around 6. what do i need to do. my method are convert it to a vcd with tmp and then author it. some1 suggest dvdshrink. i have never use the prog before but how much can you possibly shrink?
Results 1 to 17 of 17
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
420 minutes is easily 352x240 resolution. And to look good, just give it good bitrate, VBR MPEG2
HOWEVER ... I question a "good" rating on a disc with 7 hours of content.
While not totally impossible, the odds of having the source is ..well.... not very large AT ALL.Want my help? Ask here! (not via PM!)
there's no reason at all to downgrade the quality that much to fit all that on one dvd since blanks are only about .30 these days. if you're gonna do something make sure u do it right the first time. just my 2 abe lincolns
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
I have tried doing that with episodes from vcd. Just load those mpeg1 (covert from dat format with vcdeasy) in Tmpgenc DVD Author.
Agreed. Even in Australia, blanks are now cheap enough that seven hours on the one disc is just plain foolhardy and wasteful. Even more so than putting one hour each on seven discs.
Three or four discs at full D1 resolution (unless your source is already half-D1) with variable bitrate encoding should be fine. In fact, four discs at $1.50 a piece, as is the mean price in Australia, would be a bargain compared to some of the other options."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
If you want save the cost of DVD-+/blanks and still retain a decent quality I would rather suggest to buy a DivX-compatible DVD-Player and encode the movies into DivX-format where you can retain much more quality if you put 10x 42 minutes on a DVD.
CU
Schmendrick -
here's a sample forgot to do so in the bigginning.
as you can see the quality is pretty good and i'd love to do this in the future. I have plenty of dvdr so that's not the issue. I find it more convenient to have the least amt of disk even though it mean to scarifice the quality a lil bit.
Will this make the file size smaller?I have tried doing that with episodes from vcd. Just load those mpeg1 (covert from dat format with vcdeasy) in Tmpgenc DVD Author.
I already have an xbox. Sometimes I let my relative borrow my dvd so just burning it as an iso with a whole bunch of avi will be a problem.If you want save the cost of DVD-+/blanks and still retain a decent quality I would rather suggest to buy a DivX-compatible DVD-Player and encode the movies into DivX-format where you can retain much more quality if you put 10x 42 minutes on a DVD
thanks for all the suggestions.Computer Spec:
Use KDVD half D1 template. Get about 12+ hours per dvdr.
Cheers, Jim
My DVDLab Guides -
Sure, a panasonic dvd recorder can do 12 hours on a dvd....Haven't seen how it looks tho.
@trunksu .... that image is full of deinterlace artifacts.
Not only would I not consider that good quality, unless
it was a super super rare video, I'd not even watch it.
I cannot stand deinterlace jaggies.
If you're not sure what I mean, read this:
http://www.digitalfaq.com/capture/interlace.htmWant my help? Ask here! (not via PM!)
If <TRUNKSU> would be kind enough to give us the ORIGINAL resolution of the files in question we might get somewhere.....and possibly its format and datarate?
..... you should get 7hours of playing time of standard VCD's (mpeg1 1150bitrate plus 224mpa) on a single DVD.....which by coincidence is 420minutes (note! thats 7 HOURS and not 7 VCD's @ 74 or 80mins each) plus dropping the audio rate is possible with DVD.
And I (for once) agree with Smurfy that 'still' looks crap (imo)....but that MAY be because its WAY bigger than 352 X 288/240 res of VCD. -
It really look fine to me on my tv. I am willing to scarifice quality over quantity.that image is full of deinterlace artifacts.
I cannot stand deinterlace jaggies.Computer Spec:
And whats the audio rate..?
PS...dont sacrifice quality or you might as well record the dam things on a VCR on extended/long play....people here are TRYING to help you get the best. -
ive seen better VHS ---
Me too. But how much is one tape compare to 1 dvd. I bought 40pk of dvd+r for $3 during Black Friday(After thanksgiving). Please guy, I really appreciate your help but can you guys just give me suggestions on how I can accomplish this besiding making remarks of the quality. I am well aware of the downgrade in quality. That is not my concern as I stated before. I am just curious on how this guy was able to did what he did. Thanks and plz don't take what i wrote above in a wrong way. I just wrote what I felt and in no way intended to disrespect any1 b/c i know you guys are here to help.ive seen better VHS ---Computer Spec:
Read the second post in this thread (mine).
I said it already...
MPEG2 VBR, 352x240/288 and super-low bitrate.Want my help? Ask here! (not via PM!)
New Guy Here,will need help converting vhs and beta to dvd
By MrHawhn in forum Newbie / General discussionsReplies: 5Last Post: 3rd May 2011, 21:04 -
Mac Guy Needs Windows Help Editing Clips, Authoring DVD
By dizzie in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 13:12 -
Need filter help encoding the same as a guy did from the same dvd source
By starlight2000 in forum Video ConversionReplies: 10Last Post: 6th Sep 2009, 13:43 -
I can't believe that there hasn't been a Family Guy episode about this!
By zzyzzx in forum Off topicReplies: 7Last Post: 11th Feb 2009, 03:51 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 23:53
