Major,
Having trouble extracting subtitles. Here's the error I get:
#DEBUG: setac((0x00)) makes no sence!
# list box dots=0 c=(?) ac=(?) mod=(0x00) line=2 m= 0 6 24 31 r= 17 0
# list pattern x= 442 371 d=165 32 t=3 1
(@@@@ etc...)
The upper char was not recognized. Enter correct ASCII char, "string" or 4 to 8 digit hex unicode:
This happens with every word. I saw a similar post and entered the two commands in terminal that you suggested with the following results:
ls -l /usr/local
total 0
drwxr-xr-x 6 kurtport staff 204 2 Jan 01:17 include
drwxrwxrwx 30 kurtport staff 1020 2 Jan 01:17 lib
drwxr-xr-x 7 root wheel 238 18 Oct 20:57 share
drwxr-xr-x 3 root wheel 102 23 Apr 2004 var
drwxr-xr-x 10 root admin 340 20 Jan 20:52 vscanx
ls -l /usr/local/etc
ls: /usr/local/etc: No such file or directory
Thanks for your help!
K
You can check with the Finder too. That location is not hidden and freely browsable by clicking on the subsequent folders (first Library then Application Support then ffmpegX).
This seem normal. Are you able to send me to major4@mac.com a link to download a clip of your file, so as I can test?
OK, I jumped the gun and I deleted all ffmpegx files and reinstalled. Now when try to paste in
ls -l /usr/local
in Terminal I get my info, plus two returns (keystrokes) before I hit the return key at all. Weird.
Same issue as before when I try to extract subtitles only now when Terminal pops up, the two returns thing makes it impossible to enter the text correctly.
I'm left with a couple hundred Graphic Converter files in my save as location so that part is working
It's a 1 gig VOB so I don't think I can post it...
K.
Changing subtitle error!!!
By Aandis in forum SubtitleReplies: 11Last Post: 28th Jan 2012, 13:31 -
GfD - Subtitle error
By michcio in forum Authoring (DVD)Replies: 14Last Post: 4th Jul 2009, 10:17 -
MKV Merge subtitle error
By zzyzx2 in forum SubtitleReplies: 2Last Post: 2nd Jun 2008, 00:44 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 02:35
