Going to be posting results of this burned @ 4x on my NEC 3500.
Seth
Results 1 to 10 of 10
:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
Archived DVD Scans
DVD Info (Please note, this disc isnt burned quite to the edge).
Archived DVD Scans
DVDInfo
Archived DVD Scans
Archived DVD Scans
I don't want to get carried away like I did once before in one of your threads, but those spikes...are very suspect (as in possibly inaccurate). Errors that high should cause MAJOR slowdowns in your transfer rate test, but there's no slowdown at all where those errors are being shown on the disc. Confusing
Do the spikes show doing the PI/PO quality test with Nero CD-DVD Speed?
Steve, I was using my PC at the time, and had already started a re-scan, without heavy PC usage.
When I get spikes like this, I ALWAYS rescan to see if I can duplicate results. I am editing the prior post with the current scan.
And by the way - the other thread you're talking about, (I believe CMC-R), I scanned several discs burned on several writers, all with the same results.. :P Not just one instance, heh. So I stand by those results.:star: :star: :star: :star:
Archived DVD Scans
And by the way - the other thread you're talking about, (I believe CMC-R), I scanned several discs burned on several writers, all with the same results.. Not just one instance, heh. So I stand by those results.
I just felt I needed to comment as that scan looked VERY suspect, I didn't trust it was accurate just by looking at it. It appears my suspicion was warranted :P I typically HATE Optodisc, worst discs I've ever used were some old -R discs, but I've used some of the OR8 discs (8x +Rs) and they are actually pretty good discs. Everything I've heard about these OR4 discs seems to say that they are of very similar quality to the OR8 discs. I don't feel like trusting them though, I've had some HORRIBLE Optodisc media in the past.
Your scan looks very similar to my OR8 scans, minus the one spike. It's interesting that your first scan was so messed up from overuseage, I've never had issues doing scans while multi-tasking on my computer. (My processor is hyperthreading though, so maybe that makes the difference). -
Steve, I was ripping another disc on NEC (using DVD Shrink), and have TMPG Encoder going as well..both in low priority though.
It's the DVD Shrink that screwed the scan, though, i'm pretty sure. Heh heh...both on the same IDE channel, and all...as normally TMPG dosnt hurt my scans.
Seth:star: :star: :star: :star:
Archived DVD Scans
Printable BDR media recommendations?
By rysktkr in forum MediaReplies: 9Last Post: 2nd May 2011, 04:06 -
Need help downloading an MMS stream, details and code inside...payment
By robbo64 in forum Video Streaming DownloadingReplies: 3Last Post: 10th Apr 2011, 19:11 -
Media Player Classic and subtitles inside TS files
By boulder in forum SubtitleReplies: 2Last Post: 19th Sep 2008, 16:55 -
Need recommendation for printable media
By fazza8 in forum MediaReplies: 0Last Post: 23rd Nov 2007, 15:10 -
Best Printable CD media
By r00kie in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2007, 19:39
